Question vidange
le 19/08/2007 à 18:51
Hello
Je vais faire ma première vidange
Un élément que je n'ai trouvé nulle part dans les articles, c'est la qté d'huile qu'on sort de la bâche et la qté du carter moteur
Merci, Fanof
le 19/08/2007 à 18:56
fanof , quand tu as vidangé , tu remets dix litres , tu roules et quand c'est chaud et véhicule a plat , tu fais le niveau .
on vous l'a dit et répété .
Sais pas avec precision mais quelque chose comme 1/3 du carter 2/3 de l'autre.
Lors d'un vindage il y a un mois il m'est arrivé un petit désastre et j'aurais préféré que ce soit l'inverse (j'ai passé plus de temp a netoyer qu'a vindager )
le 19/08/2007 à 18:59
Ne te trompe pas d'écrou ... prévoit filtre et joint ... ne perds pas le bouchon .....
Pour la bache et le moteur ... je dirais environ 6 litres chacun , mais je dis peut-être une connerie !!!
En tout cas Fanoff si tu nous re-re-re-re-re-re-re-re-re-re-re-re-re-re-re -re-re-re-re-re-re-re-re-re-re-re-re-re-re-re -re-re-re-re-re-re-re-re-re-re-re-re-re-re-re -re-re-re-re-re-re-re-re-re-re-re-re-re-re-re -re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-re-re-re-re- re-re-re-re-re-re-re-re-re-re-re-fait un sujet sur " quelle huile pour ma Porsche ? " Je te grille les parties sensibles de ton anatomie masculine sur le BBQ !!!!
Sérieusement ... fait gaffe de pas te brûler avec l'huile ...moteur !!!
le 19/08/2007 à 19:00
ben mon Fanof .... rapelle toi de Fernand Reynaud .... c'est obligatoirement une certaine quantité
Non pas la tête ... pas la tête !!!!!!
le 19/08/2007 à 19:02
Warf, bande de moqueux de gins
Merci Rana, un de sérieux
Je vais donc prévoir un bac de récup de 10l pour ne pas me faire avoir
Pour l'huile, je fais entière confiance à notre patoun qui m'a dégotté de l'huile
Fanof
le 19/08/2007 à 19:03
et moi , je suis pas sérieux
bon , je boude
le 19/08/2007 à 19:07
Mon marsouillinouninet des bois de la nuit des temps du babou du bout de là bas après le coin de la rue qui tourne
Siiiiii tu es très sérieux, surtout quand tu nous parle de tes précédentes copines
Oui, chui déjà loin, entrain de raviver le BBQ
Fanof
le 19/08/2007 à 20:47
Si t'es adepte du poele à pétrole, un bidon de 20l avec un flanc coupé au cutter pour qu'en hauteur ça passe. Et roulez jeunesse
le 19/08/2007 à 21:07
si mes souvenirs sontbons il y a 3litres dans le moteur.... en résiduel et le reste est dans le réservoir mais bon tu fais premier le carter ..... ou le réservoir ..... comme tu veux
le 19/08/2007 à 22:29
dans la bache y a 7 / 7.5l
dans le moteur 3/ 3.5l
le reste dans les canalisations.........
bonne vidange .
lolo
le 19/08/2007 à 22:34
Dixit pollux06ben mon Fanof .... rapelle toi de Fernand Reynaud .... c'est obligatoirement une certaine quantité
Non mon cher cen'est pas une certaine quantité mais un certain temps
Histoire qu'il n'avait d'aillers pas inventé mais pompée dans le très officiel manuel du soldat aussi incroyable que cela puisse paraître .
Prière de réviser ses classiques
le 19/08/2007 à 22:35
Dixit fanof911Hello
Merci, Fanof
T'as combien de merguez et combien de saucisses a griller ????????????
le 19/08/2007 à 22:40
Je sais bien CERE ... la question était combien de temps met un affut de canon de 75 pour refroidir ?
J'ai juste adapté la réponse à la situation ... tel le caméléon moyen
le 19/08/2007 à 22:52
Dixit pollux06Je sais bien CERE ... la question était combien de temps met un affut de canon de 75 pour refroidir ?
Oh un fut PAS un affut
le 19/08/2007 à 22:55
et un fut d'huile d'olives, première pression...
le 19/08/2007 à 22:59
Pollux du même auteur et pour les littéraires :
Question : De quoi sont les pieds du soldat ?
Réponse : Les pieds du soldat sont de marcher
Dire que des millions de pôvres types ont appris ça par coeur .
le 19/08/2007 à 23:23
Dixit 911ducatet un fut d'huile d'olives, première pression...
Ben justement : Un certain temps
le 20/08/2007 à 12:44
Merci pour vos clarifications
Je vais encore dormir moins c*n ce soir
Fanof
le 20/08/2007 à 20:08
Dixit fanof911Merci pour vos clarifications
Fanof
Dis Richard, pourquoi tu poses cette question, tu ne m'avais pas dit que tu vidangeais au dessus de la bouche d'égout en face de chez toi?
Que dois je faire, j'étais déjà dehors
